-   Ford Contour (https://www.fordforum.com/forum/ford-contour-33/)
-   -   1999 Ford Contour Problem with brakes and turn signal (https://www.fordforum.com/forum/ford-contour-33/1999-ford-contour-problem-brakes-turn-signal-10704/)
orechia Nov 29, 2007 10:56 PM
Need help: The 2 Back brake lights do not work...the 3'rd ...small one on top does. None of my Turn Signal work either....front or back. Also turn signal flashers do not light up on my dashboard either. Any suggestions???
btexpress Dec 21, 2007 07:53 PM
RE: 1999 Ford Contour Problem with brakes and turn signal
Best guestimate would be the combo switch on the steering column...
bodmd98 Dec 30, 2010 06:04 PM
More likely melted terminals in the multipin connector(female) that attaches to the multifunction switch. Fabricate from universal available from Ford. Look at pictures at your dealor's parts counter. Original no longer in the system.
