-   Ford Contour (https://www.fordforum.com/forum/ford-contour-33/)
-   -   instrument panel on 1995 contour (https://www.fordforum.com/forum/ford-contour-33/instrument-panel-1995-contour-4245/)
triley301 May 29, 2006 03:48 PM
I have recently had all of my instrument panel lights go out. That includes the instrument panel, the ac illumination switches and the radio lights. I have check all of the fuses under the dash and they are fine. Is there a relay that I should change or a circuit breaker somewhere else.
joejoe Sep 3, 2006 02:17 PM
RE: instrument panel on 1995 contour
light out on contour 96 instrument panel fuses are good
94 4x4 ranger Sep 3, 2006 07:43 PM
[sm=welcomesign.gif]If the fuses are good I would suspect the dimmer switch.
94 4x4 ranger Sep 3, 2006 07:47 PM
[sm=welcomesign.gif]If you have 1 light bulb out you will have to take apart the insturment cluster to replace it.
