Replaced engine - won't start
1996 Ford Contour with 2.0 engine
Original engine overheated, purchased salvaged engine and installed over Labor Day Installed several new parts like timing belt, water pump, radiator, etc. Put old flywheel on replacement engine. Repaired insulation on several wires coming across top of radiator Engine will turn over, but not start Had to replace crankshaft sensor plug with best available fit from junkyard Power is present at coil pack, fuel rail, and crankshaft sensor Have fuel pressure, but no injection, also no spark at plugs Swapped old crankshaft sensor, no help No codes indicated on analyzer |
