'04 Crown Victoria HVAC Problems-Need Help!!!
Old 07-13-2017, 03:43 AM
Iamgrim3's Avatar
Default '04 Crown Victoria HVAC Problems-Need Help!!!
So I'm driving down the freeway a/c blowing out the vent (like normal) until it hit about 55 mph. Then it begins blowing out the defrost right....well then I begin to slow down , and it comes out the vent again. Now I've noticed it does this Everytime I accelerate for an extended period it switches to the defrost output and when my speed goes back down it goes back to normal.
Im thinking it may be a vacuum line ...anyone had this happen????
Old 07-13-2017, 09:27 AM
Welcome aboard..
The default position is Defrost. With system vacuum applied the other vent selections are done. If a vacuum leak, anytime the available vacuum falls off,, Defrost..
Check the lines, canister/ check valves, any place it can bleed off vacuum..
Iamgrim3
10-03-2018 08:45 PM
mace
11-01-2013 04:55 AM
cvsport2004
05-22-2013 11:57 AM
bburt2
09-11-2005 06:40 PM
SoldierUnknown
08-17-2005 12:31 PM
Quick Reply: '04 Crown Victoria HVAC Problems-Need Help!!!
