A/C issue
Old 04-20-2019, 11:05 AM
Mack Ward's Avatar
Default A/C issue
2004 Ford Crown Victoria, hot weather stop and go traffic a/c will not blow cool air, get back on the highway and will work..
Does not run hot. Has freon, compressor works, radiator clean.
Whats the issue? Compressor Ideal Switch???
Old 04-22-2019, 04:49 AM
raski's Avatar
Can be a vacuum issue with a blend door.
Old 04-29-2019, 09:46 AM
Use Common Sense's Avatar
Could also be borderline low on refrigerant charge. Have you verified that the cooling fans are operating properly? They may not be coming on in the "HIGH" speed when you need to move more air in the stop and go traffic which is when you need the air flow.
Chifilli
03-24-2015 08:54 AM
RH2OMAN
11-23-2011 03:57 AM
fblevins1
04-30-2009 07:56 PM
mattman
07-05-2007 09:37 PM
gtam03@aol.com
11-20-2006 12:24 PM
Quick Reply: A/C issue
