Engine stalls when warmed up
I have a 1985 crown vic that stalls when the engine comes up to temp. I have replaced the ignition coil and the starter relay. I have also replaced the muffler and tail pipe. Does anyone have an idea as to what else might be wrong?
RE: Engine stalls when warmed up
Have you had the ignition module checked? That era Ford was bad about the module failing .
Have replaced I Mod but still has problem, thanx for input, any other ideas.
I made mistake it was not the ignition coil I changed but the ignition module. Also the car was laid up for about 18 mths, I put in new battery and did a tune up (oil change, spark plugs, radiator flush and tranny flush). Should I change the I coil?
Does the car start back immediately or is it slow or hard to start? I assume it is carbureted, so is the choke opening when the engine is warm? Can you tell if it is losing spark when it stalls? Sorry about all the questions, but it will make it easier for us to offer information.
Pull the pulg from your MAF.................if it runs better, clean it or replace it. My 93' ran like crap suddenly.................unplugged the MAF. It ran like a rocket! I just replaced it with an MAF from a 96'.
OK I checked the spark on the plugs . I get a good spark before I start the car when it is cold. After the car warms up about 10-15 min the car dies, when I check the spark after it dies it is very small or not at all.
By MAF do you mean the Mass Air Flow sensor. If so, tell me where it is located on a "85" CV. Thanx
