I need help (vibration)
gents,
i have 2010 grand marquies which same engine of crown victroia
i have a low vaibration in the engine, i changed the sparks+coils but still no improvments!
So what do you think ?
also if the fuel is low check engine start flushing but if the fuel is above the mid there are no flushing!
any one have any advice?
thanks
thanks
so the code was what? p0307? it would be helpful to know all the dtc before offering advice or else we chase the wrong problem.
if you are sure the misfire is on cyl 7 only. the next step would be a compression test.
if you want to a quick check of the injector; a noid light check or listening for the injector to click with a mechanic stethoscope will tell you if the injector is opening.
thank you guys for your helps
yes the code is p0307 misfired
can you tell wheres no#7 ?
if i am in the front of the car and the bettery on my left hand and the air filter on my right hand how can i know which is coil #7 ? might be i have to deep check it
so help me on that and i wall work on it
thanks alot for all helps
only at the top(head of the coil#7)
