Looking for a copy of TSB
Hello,[align=left][/align]I'm looking for a copy of the following TSB[align=left]96234 NOV 96 EGR - Intermittent MIL ON/Multiple DTC's Set [/align]
I'm working on my daughters 94 Crown Vic with the 4.6 PI engine, and its returning a 332 (insufficient EGR flow) code. All of the checks that I've done appear toindicate that the EGR passages are clogged. I'm trying to get the car running better before my daughter sells it (dirt cheap) to a single Mother friend of hers. They work as nurses together, and she is in desperate needof reliable transportation I don't have a manuals for this vehilcle, and so I'm trying to work through this problem doing research on the net. Any help would be appreciated. |
RE: Looking for a copy of TSB
EGR - clean the passages and add a new valve. Carb cleaner might help some on a q-tip unless you have a small wire tube brush.
http://www.fordtechservice.dealercon...1527/adobe.gifPrintable View (52 KB) TSB 96-23-4[/align] [*]DETONATION - 4.6L - INTERMITTENT MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - DIAGNOSTIC TROUBLE CODES (DTCS) 332, P1407 AND/OR P1408 UNDER NORMAL DRIVING CONDITIONS[*]MALFUNCTION INDICATOR LAMP (MIL) - INTERMITTENT ILLUMINATION - DIAGNOSTIC TROUBLE CODES (DTCS) 332, P1407 AND/OR P1408 - 4.6L - DETONATION UNDER NORMAL DRIVING CONDITIONS [/ul][/align] Publication Date: NOVEMBER 4, 1996 FORD:[/align] 1992-1995 CROWN VICTORIA 1994-1995 THUNDERBIRD LINCOLN-MERCURY:[/align] 1991-1995 TOWN CAR 1992-1995 GRAND MARQUIS 1994-1995 COUGAR This TSB article is being republished in its entirety to include two additional Diagnostic Trouble Codes (DTCs) for vehicles with OBD II systems. ISSUE:[/u] Detonation and/or Malfunction Indicator Lamp (MIL) illumination with DTCs 332, P1407, and/or P1408 may occur under normal driving conditions. This is due to carbon buildup in the Exhaust Gas Recirculation (EGR) groove of the intake manifold (throttle body base). ACTION:[/u] Refer to the following Service Procedure for details. SERVICE PROCEDURE[/u] [ol][*]Perform "DL" Pinpoint Test as instructed in the appropriate year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual.[*]If Step 1 does not solve the concern, refer to the appropriate year PC/ED, Section 10A, EGR System Functional Diagnosis, and perform the tests involved.[*]If engine rpm does not change when performing test "EGR3" of Step 2, and the EGR valve checks good, check the EGR passage between the intake manifold and the throttle body for carbon blockage (Figure 1). http://www.fordtechservice.dealercon...07/tb4331b.gif Figure 1 - Article 96-23-4 [*]Remove the throttle adapter from the intake manifold. Refer to the appropriate model/year Service Manual, Section 03-01, for service procedure.[*]Keep objects from entering into the intake manifold by covering the opening.[*]Using an appropriate size chisel, remove carbon deposits that have accumulated in the EGR groove (Figure 2) on the intake manifold or sealing surfaces. http://www.fordtechservice.dealercon...06/tb4332a.gif Figure 2 - Article 96-23-4 http://www.fordtechservice.dealercon...35/tsbcaut.gif CAUTION: USE CARE AS NOT TO DAMAGE SEALING SURFACES OF INTAKE MANIFOLD. [*]Brush off all carbon that has been removed, wash EGR groove and adapter surface with suitable solvent.[*]Replace Intake Manifold-to-Throttle Body Adapter Gasket (F1AZ-9H486-A).[*]Reinstall throttle body and adapter assembly. Refer to appropriate model/year Service Manual, Section 03-01, for correct torque specifications. [/ol][/ol] PART NUMBER PART NAME F1AZ-9H486-A Gasket - Intake Manifold-To-Throttle Body Adapter OTHER APPLICABLE ARTICLES: NONE SUPERSEDES: 95-18-3 WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage OPERATION DESCRIPTION TIME 962304A Clean Carbon From EGR Groove At Throttle Body - Air By-Pass - All Models 0.6 Hr. DEALER CODING BASIC PART NO. CONDITION CODE 9A589 55 OASIS CODES: 206000, 615000, 698298 [hr] Copyright © 1996 Ford Motor Company |
Thanks way2old. That's what I was looking for. I'm hoping to get to this little project this weekend.I'll need to get parts first.
