-   Ford Crown Victoria (https://www.fordforum.com/forum/ford-crown-victoria-27/)
-   -   Steering Problem (https://www.fordforum.com/forum/ford-crown-victoria-27/steering-problem-19846/)
volkwagensc6 Apr 3, 2010 08:19 PM
Steering Problem
I have a 2003 Crown Victoria Police Interceptor 4.6L. I was driving it yesterday and out of nowhere, the steering wheel got really hard to turn. I was able to still drive the car, but driving around corners wasnt easy. Naturally I assumed that it was the power steering pump. So this morning, I put a new power steering pump and pulley in the car. Much to my surprise the steering is still very hard to turn. Any suggestions on what the problem might be if its not the pump? Thanks!
rondord Oct 22, 2012 05:39 AM
this car has vas steering, check all the fuses, check connector on power steering rack below oil filter
sunfish Oct 24, 2012 06:17 PM
I personally have not had any problems but I have read where the two joints in the steering shaft can make them turn hard. It was said to spray them down and if they improved the problem lies within. Sunfish
rracer5 Mar 12, 2013 12:09 PM
My 98 had the same problem one day. Hard to turn and it wouldn't "return" to straight on its' own. Replaced the steering box - not the problem - money waisted. Finally found that one lower ball joint had all but siezed up and wasn't allowing the steering knuckle to turn freely. Replaced the ball joint (with greasable one) and problem solved. ;)
gota4d Apr 27, 2014 07:20 PM
steering box
i have an 01 4.6 and when i turn the wheel but not the tires (the play in the wheel)the rod from the steering wheel to the box moves also but nothing else moves i tried the tension screw and that made it a tiny bit better but the wheel no longer returns. would a new box probably be the answer or would it lye somewhere else?
