-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   03 e 350 cutaway (https://www.fordforum.com/forum/ford-econoline-e-series-18/03-e-350-cutaway-25642/)
utz Oct 29, 2011 12:23 PM
03 e 350 cutaway
i have a 2003 e 350 with 77k on it.lately I noticed i have been adding 1 quart of oil a week and also when accelerating at around 40mph to 50mph it sound like a rattle can coming from the engine and it loses power.but normal driving seems to be fine.i hope i explained it the right way.
hanky Oct 29, 2011 04:10 PM
Gas or Diesel?
utz Oct 29, 2011 10:23 PM
sorry gas
odar Oct 30, 2011 01:44 PM
I would be checking the pcv valve to see if it is faulty first.
hanky Oct 30, 2011 02:13 PM
I'm a little curious about the rattle noise you mention.
Usually if the EGR system isn't working correctly ( staying closed) it could produce a pre ignition/ detonation sound , but would not necessarily cause a power loss.
A knock sensor could be responding to the rattle noise and reducing timing advance which might be felt as a loss of power. Sooo,
A thorough check of the EGR system would be a good place to start checking.
A carbon clogged EGR passage, a Faulty EGR valve itself, loss of vacuum control to the valve etc. If you find the solution, please share it with us. Thanks
Lets hope there isn't a more serious internal engine problem involving the unusual oil consumption
utz Nov 1, 2011 01:06 PM
it is def a knocking sound when I accelerate aggressively.how about my fuel filter or a vacum leak? I have to bring it in soon just want to finf the right mechanic to look at it.
hanky Nov 1, 2011 02:20 PM
I really do not think a fuel filter or any type of vacuum leak would produce the knocking you describe. Usually when an engine knocks under load it involves a connecting rod bearing. We also don't overlook a loose flex plate connecting the flywheel to the torque converter. The problem is ; why the high oil consumption unless it's leaking where you can't see it. It is going to require a thorough check and there could be more than one thing wrong in there.
utz Nov 3, 2011 02:06 PM
i actually for the first time put 94octane in today and there was no pinging or knocking at all.So i will stay with this for a while and see what happens.
