1987 E-350 460CID Carb Gas Prime Problem...
Old May 21, 2013 | 06:08 AM
AF Barrs's Avatar
Default 1987 E-350 460CID Carb Gas Prime Problem...
On my 1987 E-350 460CID Carbureator Gasoline engine with one NEW fuel pump and NEW inline fuel filter element installed in the rear 40-gallon tank I have had hard starts from sometime since I believe the fuel tank and internal fuel pump are some 25+ feet from the engine carb. I am thinking about installing a 12-volt electric auxillary fuel pump (many pumps on eBay) in the fuel line between the in-tank fuel pump and the in-line fuel filter. Would this installation impede the fuel flow from the in-tank fuel pump to the carb when it is shut down after priming or is there a bypass or is a special primer pump needed? Can you tell me the best location and how to install a 12-volt electric fuel priming pump in my 1987 E-350 460CID 4-barrel carb motorhome? THANKS!!!
AF Barrs
May 21, 2013 05:53 AM
mavric460
Nov 12, 2010 11:16 AM
longearlady
Apr 7, 2010 09:59 PM
wmduncan2
Jul 26, 2009 03:15 PM
cdlray
May 9, 2008 10:58 PM
