1988 302/5.0l showing low oil with 7 quarts in it?
I have a 1988 Ford E-150 van with 302/5.0L V8, just recently changed my oil a month ago. I added 5 quarts of 10w-40 Pennzoil and a quart of Lucas. The dipstick showed like 2 quarts low, a quart under the "ADD 1 quart" line on the dipstick. The oil pressure gauge was reading 1/3rd and I drained only like 4.5 quarts out of it so I figured it was fine. Recently when I've been running it it's been right at the bottom line of "NORMAL" for the gauge, so I added another quart but it didn't seem to make a difference for the gauge. I really don't think it's burning that much oil at all, I haven't even driven it that much. No leaks to speak of. I heard overfilling it would be pretty bad for it. Should I actually add another quart or two? Could the dipstick be wrong? I haven't gotten a check engine or anything and it's been running good so I assume if it gets really bad that will come on. Any advice is appreciated.
I have a 1987 E-250 with a 302 in it. It usually takes around 7 quarts, maybe 7 1/2 quarts ... not sure exactly ... when I change it and filter. That puts it at the top of the hash marks on the dipstick (full).
My oil pressure gauge stays at the same mark even if it's a quart low by the dipstick reading.. I have never run it low enough for it to drop. Maybe you have a different type gauge. That thing of mine runs like a champ, passes the smog test with flying colors but sucks up gas to the tune of 8 MPG around town and not much more on the freeway. How is your gas mileage ? |
Originally Posted by Dexter Morgan
(Post 123066)
It sounds like all is working out for you ... great !
What kind of mileage are you getting ? |
(Post 123077)
What kind of mileage are you getting ? The 85 that I had with a 302 got about 12. |
