-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   1999 E-150 Riser tube from intake manifold broken (https://www.fordforum.com/forum/ford-econoline-e-series-18/1999-e-150-riser-tube-intake-manifold-broken-33118/)
RedEric Apr 25, 2015 12:09 PM
The riser tube is cracked and leaking on my 1999 E-150 cargo van. While removing the hose from the tube the entire tube broke off. I was wondering, do I need to remove the intake manifold to fix this?
hanky Apr 26, 2015 08:28 AM
If it is the part I believe it to be, it is replaceable without removing the manifold. Check with a Ford parts dept.,they should be able to tell you if they have one.
