Coolant leak
Old 03-11-2018, 09:15 AM
ps0303's Avatar
Default Coolant leak
I have had a off and on coolant leak for sometime now. It used to only leak when it was really cold out. I've had it in several times and the pressurized the system and found nothing. This weekend I noticed a leak under the van and sure enough it is coolant. It's not cold out. I crawled under the van and I can see where I think it's coming from. However, I have looked to see what this piece is and I can't identify it. I was thinking it was the water pump but I don't think so. The water pumps I have looked at don't have lines attached to it like this unit does. This is on a 2002 E250 5.4L.
Old 03-12-2018, 02:59 AM
When hose connections get warm they expand and sometimes enough to not leak even when under pressure.
The secret is to pressure test the system when cold.
Old 03-12-2018, 10:27 AM
ps0303's Avatar
Well I left it at the repair shop this morning to have them look at it. If they call and say they can't find it, I might tell them to replace the water pump. That is what I really think it is for some reason. I have had it to them several times in the past and they couldn't find it and I'm just fed up with it.
IAHAWKS
03-01-2008 05:00 PM
alldonein
12-13-2007 06:48 AM
jr1017
07-25-2007 09:54 AM
kbsc
05-07-2006 04:53 AM
kpmc1206
05-08-2005 05:10 AM
Quick Reply: Coolant leak
