2006 E350 superduty van transmission leak
Hi. New to the forum and not very mechanically inclined, but I thought it possible I may be able to fix my vans issue with some advice. My van is not holding transmission fluid whatsoever and leaking from a wobbly bolt when I add it. I will add some pics. I need advice on the name of that bolt/ area that needs repaired, if itself is the actual problem. I should add that bolt is free spinning as if the top of the bolt isn't actually connected to the shaft of the bolt, making it impossible to loosen/tighten.
https://cimg5.ibsrv.net/gimg/www.for...005762a2e2.jpg I appreciate any and all advice as attempt to fix this issue. Thanks again. |
That's the trans case vent. The cap is supposed to be loose.
How many miles on the trans, and OD/Tow Haul lamp flashing? |
(Post 127905)
An overfilled transmission will send fluid out the vent.
| All times are GMT -5. The time now is 08:18 AM. |
