2010 E-350 how to remove stock radio ?
I cannot find info on this model how to remove stock radio to swap out for aftermarket one, tried googling but it all shows old dash design from previous years.
Here's the dash that I currently have in mine. http://images.hgmsites.net/lrg/2010-...00245192_l.jpg |
Here you go. Hop this helps. 2012 and 2010 have the same dash.
Jim How do you remove the factory radio from a 2012 e250 van? |
For what it's worth,
Ford products do not like add on equip. What I am trying to tell you is; Maybe right away or sometime up the road if your vehicle should develop a no start problem leave yourself an out to disconnect the replacement radio. As far as the network system is concerned your present radio is considered one of the modules in the network. When a module is open or changed the network can develop communication problems and some of them can result in a no start condition. I would strongly suggest that you check with a Ford dealer service dept before changing anything. |
youtube to the answer
