2010 E350 instrument cluster cycles on and off
Old May 22, 2021 | 07:51 PM
Steve2206's Avatar
Default 2010 E350 instrument cluster cycles on and off
Hello All,
Problem started immediately after pulling the dash and instrument cluster off to access transmission shifter cable and replace brake-shift interlock.
Instrument cluster repeats the following sequence consistently about every 8 seconds either while vehicle is running or key is in ON position.
Vehicle continues to operate normally while driving.
Vehicle: 2010 Ford E350 Superduty cut-away bus, 170k
Sequence detail:
1. Oil Pressure/ tachometer / fuel / temp / charge / odometer / trip meter /cluster backlight - go dark, analogue gages go to zero
2. analogue gages return to normal but cluster backlight is remains off
3. All warning lights in center of cluster – light up brightly
4. Odometer - lights up brightly (headlights Off mode)
5. Warning lights in center of cluster - go off
6. Odometer/brake/airbag/ battery/ engine -remain on
7. Odometer/brake/airbag/ battery/ engine -off & on very briefly, then Trip meter lights up
8. Cluster backlight returns to normal, odometer brightness returns to normal (headlights On mode)
Time for above sequence about 4 seconds. Time to repeat about 10 seconds.
Attempted fixes:
Checked Cluster fuses, OK.
Checked cluster plug for looseness. Reassembled. Same problem.
Thomas Johnson Jr.
Feb 25, 2020 02:24 AM
EStein9077
Jan 19, 2018 07:33 AM
CueBall
Jun 4, 2016 04:48 PM
sectlandscaping
Dec 6, 2013 10:27 AM
Kevin Langton
Aug 16, 2012 09:28 AM
