-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   2010 Ford Econoline Fuse Panel Location (https://www.fordforum.com/forum/ford-econoline-e-series-18/2010-ford-econoline-fuse-panel-location-30657/)
FFrancis Sep 27, 2013 03:26 PM
Hello All!
I just recently purchased a 2010 Ford E-150 Passenger Van. I drove it 80 miles home, and it was wonderful. Smooth ride, and very comfortable. I'm Very pleased with my purchase.
I am having just a bit of a frivolous issue. All of the dome lights seem to be work when a door opens. The only thing is when I move any of the dome light switches to the "ON" position, nothing happens. Also the front dome light has 2 switches, to the right and left of the, I believe they turn on "map lights" anyway neither of those map lights seem to be working, as well as the visor mirror lights don't come on when you open the lid. I wasn't sure if they are on some separate fuse. I checked the bulbs, and they seem to be okay.
Can anyone please advise if my theory is correct, and maybe point me in the right direction to the fuse panel. I was able to find the one under the hood, but I searched for the inside panel, and I can't find it anywhere.
Thanks everyone!
hanky Sep 27, 2013 06:13 PM
The inside fuse panel is located at the left side of the dash just above the parking brake pedal.
hanky Sep 27, 2013 06:17 PM
You may need to remove the plastic cover located under the steering wheel to see it. Just give the screws a 1/4 turn counterclockwise and the panel will fall off in your hand.
FFrancis Sep 27, 2013 10:23 PM
Thank you hanky!!
I didn't see any cover, it may be missing, but found it right away, just followed the parking brake.
If anyone is having the same issue, fuse 25 (demand lighting). Controls the dome light switches and sun visor vanity lights.
