2016 E450 Motorhome
Hello All,
Just purchased a new motorhome with the E450 engine, currently 2300 miles, and noticed a knocking sound when turning in either direction. The knock only occurs when moving and turning. Bushings, tie rods, cv joints all look good and tight. Any ideas. Thanks John |
Might be a typo, but there usually aren't any cv joints on those vehicles.
Best to have the dealer check it out. Sometimes the steering stops will make a noise when at the end of the turning angle against the stops. |
You mean you have an E-450 chassis built motorhome. The E-450 chassis' come with either the 5.4L V8; 6.8L V10 2V; 6.8L V10 3V engines depending on how the dealer orders them for use and equipage build. The 6.8L V10 2V is the most common motor home chassis engine. The E-450 still uses the twin I-Beam suspension in them. Since it's under warranty, definitely have it looked at by the dealer as Hanky stated.
Hello, I have a 2016 e450 super duty with 23k mile's on it. it has a p0305 and p0316 code.
I've replaced plugs, coil, injector, and still have cylinder 5 misfire. same codes remain. need help please... |
