83 Econoline turn signal flasher
Can anyone tell me where the turn signal flasher is on an 83 Ford Econoline. I've looked all around the fuse box and other areas. Thanks
RE: 83 Econoline turn signal flasher
The flasher on teh fuse box is the 4-ways. You must be able to stand on your head to find the signal stat. It is on the left side of the steering column right around where the column bolts to the dash. If it doesnt seem to want to come loose just force it. It is snapped into a bracket that is welded to the column.
