93 e150 conversion keyless entry ??
Old Jun 26, 2012 | 12:13 PM
pizzafellow's Avatar
Question 93 e150 conversion keyless entry ??
Hi ya all
I have a 1993 e-150 5.0 liter 302 v8 engine vin# 1FDEE14N8PHB87126
When I bought it used it came with a type 2 keyless remote(3 buttons) that worked.
I once reprogrammed it by turning the ignition on/off ten times while pressing the lock button, and it did enter the programing mode and the locks cycled. And the remote worked.
Now I lost that remote and bought one(off of a ford minivan) from the salvage yard. It's also type 2 I believe with the following info:
Transmitter 1
FCC ID GQ43VT4T
DOC 1470 K763
TRW INC 3165189
This remote(with new batteries) did not work. I tried the ignition on/ off 5 times, 8 times, and ten times while holding one of the buttons and then without holding the button( pressing the button at the end with the ignition on) but I could not get into the programing mode.
I also tried to jump the 2 programing connectors under the dash but to no avail.
Any ideas or comments will be much appreciated.
Old Jan 8, 2013 | 01:01 AM
jdub's Avatar
Hey Pizzafellow, Did you ever find a solution to your keyless entry problem? I have a 94 150 conversion. When I bought it, the previous owner couldn't find the keypad. So I bought a replacement and went through the programming instructions. When I jumped the programming connector, the locks never cycled. I was hoping you found the fix and could offer me some advise..
Thanks,
Jesse
leo2947
Mar 5, 2007 04:02 PM
Stryker
Nov 19, 2005 01:42 AM
93Miata
Nov 11, 2005 04:42 PM
mdbell
Sep 24, 2005 01:40 AM
ZMonte85
Jul 9, 2005 03:11 PM
