-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   96 E150 Running like the choke is stuck! (https://www.fordforum.com/forum/ford-econoline-e-series-18/96-e150-running-like-choke-stuck-10972/)
Fordfanforever#1 Dec 17, 2007 07:03 PM
:eek:My 96 5.8 E150 isputting out dianostic codes of P0153,P0401,+P1151.This last code on the tester says Manufacturer Control Fuel Air Metering,This is not what I found when I looked up that code.It said lack of up stream heated oxygen sensor switch lean bank #2.Can any one help?
BRETM Dec 18, 2007 12:15 PM
RE: 96 E150 Running like the choke is stuck!
The P0153 and P1151 are for O2S21 (bank 2, sensor 1) Lack of switching. Could be a vacuum leak, misfire, exhaust leak or just a bum O2 sensor causing this.
Gary2Wheels Mar 5, 2008 09:18 PM
have you checked the MAP sensor?
