Can I use a rust inhibitor over existing rust on fuel lines and fuel tank?
Just bought a 98 E150. The frame is solid but I didn't realize how rusted some of the underbody is until I looked at it more closely at home. Instead of replacing the fuel lines, gas tank, and filler neck right away, is it possible to use a rust inhibitor such as stabil rust stopper or some other rust protectant oil to prevent this from getting any worse?
https://cimg7.ibsrv.net/gimg/www.for...61a3d377d9.jpg Fuel lines by driver wheel well https://cimg0.ibsrv.net/gimg/www.for...17ac5e0307.jpg Fuel neck https://cimg5.ibsrv.net/gimg/www.for...7a7144aa5f.jpg Fuel tank |
You have a lot of work before you. Two steel lines most important to REPLACE ARE THE BRAKE LINES AND FUEL LINES.
If a brake line develops a leak, pedal goes to floor, Big problem, If fuel line to engine leaks , may not start or run and Hope you don't smoke near the vehicle. |
