Dip stick length -E4OD Trans.
I have a 1995 E150,4.9 in-line 6 cylinder w/E4OD overdrive trans. It has the wrong dip stip in the trans & I can't get a true fluid level reading. ANYBODY - Can you give me the o/a length of the proper dip stick - please & Thanx. Ray
This probably won't help you very much, but if you drain the torque converter , it does have a 1/8 pipe plug there, and drop the trans pan and change the filter 14 quarts will bring you to the full mark on the correct dip stick. If it has never been changed, might be something to think about.
Thanx - Dip stick info.
Hanky: Thanx for the reply. Can U tell me of a link that would give specs. on parts or some kind of contact for Ford parts?? Thanx; Ray
Anybody ????? Pls help me !!!
I usually check with any Ford parts dept. If they can't get one for you they will usually give you the part #. Once you have a part # you can shop around.
