e-350 DPFE location
I have a 99 e-350 Super Duty XLT van. I'm trying to find the DPFE or EGR valve location. I can't find it. Any help would be appreciated. Pictures would be great. Thanks!
You may need to remove the doghouse cover inside the van to see the EGR Valve and DPFE sensor. They should be located at the rear of the engine,
Thanks! I ordered a DPFE15 replacement. Is this correct? I don't see this at all.
Did you order this from Ford?
The DPFE sensor is not used on all vehicles. If you trace the vacuum hoses coming from the EGR valve housing , two of them should go to the DPFE sensor. |
What symptoms are you getting to feel the EGR/ DPFE sensor are involved?
I'm getting a CEL. Sorry for my naivete, I'm new at this.
What codes were you able to get from the PCM ?
