-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   E-450 bus conversion AC questions. (https://www.fordforum.com/forum/ford-econoline-e-series-18/e-450-bus-conversion-ac-questions-30153/)
roach711 Jun 30, 2013 03:53 PM
Hi all!
I have a 2000 E-450 cutaway bus (7.3L diesel) that originally had the AC condenser and fans mounted on the roof with no engine mounted condenser. I removed that system to make room for the RV conversion and now I'm working on restoring the AC system back to a "normal" van (front only) AC.
I've removed the old rear hoses and installed a new condenser in the engine compartment and also replaced the accumulator/dryer, the orifice tube and one of the low pressure hoses. The old system was holding pressure when I removed it and the old orifice tube was squeaky clean. The AC sticker inside the hood is for the old roof mounted system so I can't use those specs.
I'm getting ready to recharge the system so what I need to know is the amount of oil and refrigerant to add. Also, is it best to remove the compressor and drain/replace the old oil or can I just add new oil by opening the low pressure return hose and pouring in the new oil before vacuuming and recharging?
Thanx! Rick from Farmington
roach711 Jul 1, 2013 08:25 PM
I found the specs on another site.
44 ozs of R134a refrigerant
9 ozs PAG 46 oil.
Draining and replacing the compressor oil is the preferred method.
