Econoline E350 XLT
Hello. I have a Ford Econoline E350 XLT van. It recently has started having issues with the blower fan for the air conditioning. When traveling up hill or accelerating, the blower fan idles very low to the point it’s as if it has shut off. When leveling off or desired speed limit is reached the fans return to normal blowing. What could be the problem?
thank you. |
We don't know at this time if it is a possible electrical or physical problem.
Might be a good idea to remove the blower motor and see if there is anything interfering with the motor running. |
Originally Posted by Ineedhelpplease
(Post 132294)
thank you. |
(Post 132300)
so there is a check valve to a vacuum reservoir in the dash that often goes bad, so that there is not enough vacuum to run the climate controls. To get at the check valve is exceedingly difficult, so the fix is to cut the vacuum line supplying vacuum to that reservoir, and re-route it through the doghouse into the cabin, where you can install another reservoir and check valve near the glove compartment and rejoin it to the climate control system. There are several videos on YouTube showing this, just search for Ford e350 vacuum defrost and check them out. I did it on mine about 2 years ago for about $40, and has been working fine ever since
I agree with Brad, the symptoms do point to a check valve problem resulting in the loss of needed vacuum to the the vacuum controls.
I don't know if the OP is describing his issue correctly. He didn't say if the blend doors are mode shifting back and forth with defrost. He said his "blower fan" seems to change speeds, which is strange and not dependent on vacuum.
As we all know , different folks will describe a problem different ways and we can only go by what we believe they are trying to tell us, so probably would be a good idea to ask for better details or description of just what is actually happening.
(Post 132493)
Unfortunately, by the time they get here a good number have spent considerable $$$ already and are asking for advice so they don't waste any more $$$.
