-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   to gasket or not to gasket... ? (https://www.fordforum.com/forum/ford-econoline-e-series-18/gasket-not-gasket-4766/)
JohnNetbee Jul 31, 2006 11:50 AM
THAT IS MY QUESTION !!!
Removed my cracked EXHAUST MANIFOLD...
There were no gaskets on ether side (block or pipe).
This is an original factory installed manifold on
a 1987 Econoline E-150, 302 engine
New MANIFOLD did not come with any gaskets but you
can purchase an exhaust manifold gasket kit
(which I did thinking I would need it)
At this point I don't think I need any gaskets.
I'm tempted to put it back together as I
found it (metal on metal).
Anybody out there do an exhaust manifold?
Maybe you can shed some light on this for me.
THANKS!!
boflaade Jul 31, 2006 10:28 PM
RE: to gasket or not to gasket... ?
One may wonder if thou manifold crack occurred due to noest gasket. The slings & arrows of saving the cost!;)
94 4x4 ranger Jul 31, 2006 10:32 PM
I would use the gaskets.Always have.
JohnNetbee Aug 1, 2006 09:14 PM
Just as an update here is what I have found out:
I spoke with my local FORD parts department. There is NO gasket used on an '87 Econoline. It is intended to be metal-to-metal. He did say there is nothing wrong with buying an aftermarket gasket set at Napa/Autozone/or wherever but they were not built that way... and hence do not need to be rebuilt that way.
NO the cracking hath nothing to doest with thine "missing" gasket ;-)
I'm not sure if ALL Econolines are metal-to-metal or only certain ones.
But I am certain mine does not have any (as designed by FORD).
Hopefully not a COMEDY OF ERRORS !!
Alas poor Manifold I knew you well...
[IMG]local://upfiles/6822/232B0CC943D84B5391D9BA5F95561C84.jpg[/IMG]
boflaade Aug 1, 2006 09:34 PM
All's well that exhausts well!:D
