instrument cluster replacement 1995 e250
i got a 1995 econoline e250 high top conversion van with a busted psom on the instrument cluster. i want to replace the entire instrument cluster but have some questions. im not very mechanical so forgive me for my ignorance. first of all the van is canadian so the speedometer and odometer are in kilometers. if i pull an instrument cluster from the pick n pull thats in miles not kilometers how will that affect the van? first it had about 95,000 miles on it so when the new instrument cluster is put in will the obdometer reflect this in miles or kilos? when it gets driven with the correct speed be shown on the spodometer in miles if it previously was in kilos? any advice or insight? i assume the instrument cluster in miles would be compatible to replace the current ones that shows everything in kilos but please correct me if im wrong.
There are places that repair instrument clusters.
Do you think you would rather consider that path? |
