a little help with a shorting reverse light
hi everyone, nice fourms!! so i just started working for a small company and we install custom wheelchair ramps for disabled Veterans.
the worktruck is an automatic 2005 e350 turbo diesel, and its having a few problems. the reverse light seems to be shorting out. when you put it in reverse, the reverse lights are nice and bright, but when you go into neutral or drive the reverse light blinks like its shorting, OR the switch for reverse is faulting... where is the switch for the reverse light?? these are 2 pics of some numbers i was able to get off the transmission, maybe that can help! http://img.photobucket.com/albums/v1...20608-0843.jpg http://img.photobucket.com/albums/v1...20608-0843.jpg thanks in advance!! |
The trans range sensor is mounted inboard between the solenoid body and case on the torqshift.
Sent you a PM |
thanks for the pm!
| All times are GMT -5. The time now is 10:13 AM. |
