-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   Location of turn signal flasher in '94 E-150? Have hazard flashers but no turn sigs. (https://www.fordforum.com/forum/ford-econoline-e-series-18/location-turn-signal-flasher-94-e-150-have-hazard-flashers-but-no-turn-sigs-21003/)
Glowbug Aug 30, 2010 06:41 PM
Hey all,
I've got a '94 E-150 that recently lost the turn signals - hazard lights do work. I found the hazard flasher underneath the main fusebox, but I can't seem to find where the main turn signal flasher is. Unfortunately, I don't have the owner's manual anymore, or a service manual, so I'm really going in the dark (I hate working like this).
It looks like there's a round location for a 2-pin relay with nothing in it in the main box, but the relay I was given when I asked was a 3-pin square one?
Would really, really appreciate any help. Even though everybody else up here drives without turn signals anyway, doesn't mean I like to do it :D
Thanks!
stuart40ca Aug 31, 2010 07:45 PM
It's located in the fuse panel.
hanky Sep 3, 2010 06:06 PM
From the info I have;
" On E-150-250-350, the turn signal flasher is mounted on the front of the fuse junction panel. The hazard warning flasher is mounted to the back of the fuse junction panel, behind the turn signal flasher."
Frank.Chang Oct 3, 2010 06:42 AM
is there anyone who knows more details about this?
Hanky, are you sure your information is the right one?
hanky Oct 3, 2010 07:15 AM
The info I relayed came from a 3 inch thick 1994 Ford body/chassis manual, that said ,lets go the world of past experience.
On more than one occaision I have searched for signal flashers and found them every place , but where they were supposed to be.
Unless you take the dash covering off for visable access to where the flasher plug might be taped to some harness wiring, try looking on the passenger side of the steering column. Its not the easiest thing to do with a flashlite and mirror but you just might see it if its there.
Going back to the fuse panel ,who gave you the three prong flasher ? They could be wrong and maybe a two prong is the correct flasher. unless there are no contacts for a flasher on that panel, get a 2 prong one and try it.
stuart40ca Oct 4, 2010 06:25 AM
The location I stated comes from ALDATA.
Tattedchick Jan 28, 2022 10:13 AM
Turn signals and brakes lights
Both turn signals ( but only in rear ) turn on when turning left or right. But when brakes applied they stop. What us causing this
hanky Jan 28, 2022 12:43 PM
Could be a problem with the sig lamp sw on the steering col. Did anybody change the flasher?
