Parasitic Draw Identified - Now What?
Hello, friends. I recently bought a 2004 E-250. I discovered that it has a a parasitic draw issue -- if it sat more than a few days it would not start.
Using the troubleshooting tactics detailed on Youtube ( My question for you -- someone who likely has a much greater grasp on vehicle mechanics -- is, what's the next step? Could I just pull the fuse and leave it out to eliminate the parasitic draw issue? I don't mind if I don't have a radio or an overhead light and there is no video unit in the vehicle. But might the other stated uses of that fuse -- "Battery saver relay ... Instrument cluster ... Accessory delay relay" -- be critical? I should note, when the fuse is reinserted a clicking, mechanical sound is audible. Thanks in advance for your input! |
Something you might check,
Look behind the fuse panel for any excess rust or moisture. Some models had a moisture intrusion problem from a leaking windshield.If that is evident you may need to remove the GEM (Generic Electronic Module) and clean it to remove any moisture or corrosion. |
I agree with hanky, I had a water problem but thought it was the plug in the floor... I think I will check it out.. 07..4.6..f150 STX..
Can you help us out with , as best as you can, where does the clicking sound seem to be originating?
By the way, F150-07-4.6 thanks for the support, and Merry Christmas ! |
Originally Posted by F150-07-4.6
(Post 111383)
