Power Steering Pump Pulley
Hey. I am new to this Forum. I am hoping you guys can help out. I have a 93 Ford e350. 7.3 non turbo diesel. It is a converted shuttle bus. I have a traveliing band and I am converting it into more of a sprinter style bus. My issue is......The power steering pump went out. In removing the pump, I found that the power steering pump pulley is bent. It is a metal pully for a serpentine belt. I cannot find one anywhere. My local ford dealer said they are not produced anymore also. Is there a easy swap? Is there a different pulley I can use? Any help, advice, knowledge, etc will be GREATLY appreciated. Thank you!!
DORMAN's web site shows that their part #300-020 will fit the 1993 E350 with the 7.5 Diesel.
http://www.dormanproducts.com/p-2870...origin=keyword
Then click on application and scroll down to the 1993 E350 7.5
My bad...For some reason I had 7.5 stuck in my head for the diesel. Forgot that the 460 was still around back then. Your best bet would be to measure the diameter, width of the pulley and also the shaft size of your pump. You then may find something that would work.
