Vacuum line nightmare !! Help !! (please?).
I have a 1992 ford e-series, e-150, econoline cargo van, with a 5.0 litre engine, auto trans.and is a california vehicle. Due to an extremely disgruntled x-girlfriends vindictive behavior, my vacuum line system suffered the brunt of it all. In short, its a mess. Im confident i can restore it back to normal. The only thing that stops me is i need complete, easy to understand information, (a vacuum line and its components schematic/diagram, color coded if possible, showing me what vacuum line goes where, etc, etc., i would greatly appreciate anyone that could assist in getting my vans vacuum line system back to normal. Or provide info where i can get what im looking for. Thank you so much.
Is the original routing diagram missing? It would normally be on the underside of the hood, or possibly on the core support..
Did you find the info you needed ?
Originally Posted by hayapower
(Post 140769)
is the original routing diagram missing? It would normally be on the underside of the hood, or possibly on the core support..
so much. |
Have you thought about using “just answer”? I’ve seen them pull up schematics for other vehicles, maybe it’s worth a shot if you can’t find it elsewhere, or it might be a waste of money..hm.
(Post 140834)
did you find the info you needed ?
Originally Posted by aidanw8888
(Post 140858)
have you thought about using “just answer”? I’ve seen them pull up schematics for other vehicles, maybe it’s worth a shot if you can’t find it elsewhere, or it might be a waste of money..hm.
I found a vacuum diagram for an F series 5.0L on JustAnswer. I know it's an F and not an E but it may give you some clues.
https://www.justanswer.com/car/1bvj8...um-system.html Sorry if this ends up being a wild goose chase for you. |
Originally Posted by etinpa
(Post 140866)
i found a vacuum diagram for an f series 5.0l on justanswer. I know it's an f and not an e but it may give you some clues.
https://www.justanswer.com/car/1bvj8...um-system.html sorry if this ends up being a wild goose chase for you. |
I have 2 diagrams for 1991 5.0 e150 engines.
Can you possibly get the engine calibration code from the engine? There is usually a decal on the valve cover showing that info. Do you know if your engine has a MAP sensor? I have no way to send a photo so we can do it by description, should be no problem. If info requested is not available, can you tell us which lines are still intact and approx how many were removed/destroyed.? Will check a 1992 Powertrain manual for the decal. |
