-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   Where to find a certain tool (https://www.fordforum.com/forum/ford-econoline-e-series-18/where-find-certain-tool-27903/)
topgeye Sep 1, 2012 11:28 AM
Hey, I'm new to this forum and searching for answers. I have an old 78 Ford E350 one ton that's on a motor home. I need to replace the pinion seal on the rear end. The pinion nut is a 1 5/16 six point. When I tried the socket I had, the yoke was narrow and tapered in such a way so that the socket would not fit on the nut. It appears I would need a nose down socket to get by this taper. I can't find one as yet that is made like I need. Anyone have any remedy,suggestions, or can tell me just how to get this done? Thanks for reading my very first post.
Hayapower Sep 1, 2012 12:04 PM
I have on here in my home/shop that I narrowed.
A 6 point socket (or impact) usually has thicker socket side walls. A 12 point tends to run thinner. You can take a bench grinder or an angle grinder on a 12pt. and 'rotate and cut' about 3/4 inch back thinning the wall thickness. Not too much, but enough to get the socket to pass the yoke ID without weakening the socket..
