-   Ford Edge (https://www.fordforum.com/forum/ford-edge-73/)
-   -   2013 EDGE - squeaky wheels when driving (https://www.fordforum.com/forum/ford-edge-73/2013-edge-squeaky-wheels-when-driving-40711/)
mommathomps Sep 27, 2019 07:36 AM
Just replaced front and back brakes - new pads & rotors. I have an awful high pitchy squeal/whistle when I am driving which goes away when I brake. Could it be a caliper? wheel bearing? Help! Its driving me nuts!
hanky Sep 27, 2019 02:51 PM
Can you determine the area the squeal is originating? Left front, right front ?
Once you isolate which side , start a very detailed check of everything you did.
Also , if the caliper is not free to move due to corroded pins , it might be hoilding the pad against the rotor.
Did you also clean with a rag the surfaces that the stainless clips adhere to so the pads are free to move?
Did you replace the stainless clips , they should have come with the pads.
