2013 Ford Edge Sport - Cooling Fan Issues
Old Sep 28, 2017 | 12:23 PM
Miner's Avatar
Question 2013 Ford Edge Sport - Cooling Fan Issues
Hi folks, got a query about the cooling fans after having an unsatisfactory experience at the local Ford garage.... they wanted to charge me 2500 AED (3.67-$/5-£) for a whole new fan unit, based on visual inspection that one of the fans was not working... details are follows:
  • Should both fans work at the same time? - Erm don't know
  • Is it a two stage system (second one kicks in when car gets two hot or one spools up) - Erm don't know
  • What diagnostics did you do - none
  • Why - from experience we just change, its a safety concern
  • Did you do a diagnostic test - no
  • Why not - not normally required
  • Why should I give you a large sum of money on this basis - erm....
You get the gist.... if its broken, no issues as its very hot here and my wife is too precious to kill for a few hundred quid.... however I work in power plant maintenance, so no convinced its as broken as they say. Asked them to do a full diagnostic examination and report back before I decide anything.
What I want to establish:
  • What is the logic? Both run and one speeds up? Or one kicks in at a different point?
  • What is the likelihood that the second fan simply has a broken connection / wire?
  • What is the likelihood that one of the fans is choked with dust/dirt/sand? (live in the UAE, do a lot of miles)
  • Are these units serviceable individually or is there a simpler fix?
  • Do we need to bend over and buy a whole unit?
Advice / experience / guidance welcome.... please let me know about the above. Cheers.
FSGB
Sep 29, 2017 12:41 AM
Jb6661
Jun 21, 2015 03:53 PM
Jb6661
Jun 21, 2015 02:57 PM
renatosc123
Sep 15, 2013 04:08 AM
P.A.
Nov 29, 2012 06:59 PM
