Ford Edge 2018 Trunk
Old May 6, 2023 | 01:56 PM
Britthelms's Avatar
Default Ford Edge 2018 Trunk
Recently, my trunk is not opening when my car is off. It sounds like it's trying to open but it won't. As soon as I turn the car on then it will open. It's acting like it needs more battery just to open. Please help!
Old May 6, 2023 | 02:16 PM
Welcome to the site..
If you have no cranking speed issues, or similar door lock/unlock problems, Id be suspect of the trunk release solenoid ..
Old May 6, 2023 | 02:21 PM
Britthelms's Avatar
Ok, I am not having any other lock problems. Is the release solenoid the part where the trunk releases and closes? It almost looks like a hook?
Old May 6, 2023 | 02:40 PM
Its part of the lift gate latch. The trim panel would need to be removed to gain access.
Unless the latch is bound (debris etc), it would seem it would be weak, more so if with the engine running (more available voltage) the op is then normal..
OE battery?
Studz
Mar 1, 2023 02:48 PM
lance195072
Jul 24, 2022 02:25 PM
rmp0012002
Aug 20, 2018 11:01 AM
rmp0012002
Apr 27, 2018 09:39 AM
lynnie10
Jun 27, 2010 02:00 PM
