-   Ford Escape (https://www.fordforum.com/forum/ford-escape-19/)
-   -   2002 V6 Escape Instrument Cluster resets itself while driving (https://www.fordforum.com/forum/ford-escape-19/2002-v6-escape-instrument-cluster-resets-itself-while-driving-23779/)
sharkyg60 Mar 8, 2011 03:44 PM
I have a 2002 V6 Escape XLT with all the options. The problem is that when driving at random times, the Tach and the Speedometer pinned all the way to the right then go to zero and back to where they should be. It seems just before that happens, the car hesitates just a bit, if any. Any help would be great!!!
Todd
Douglas_48 Mar 8, 2011 06:16 PM
Todd
That sounds like it could be an electrical issue or something in the wiring... Hillsboro Oregon Mercedes Benz Auto Repair Mechanic Service Center
Nilsa Apr 9, 2011 06:20 PM
Hello ! I have the same problem; did u find out what was wrong? Tku
Nilsa
hanky Apr 9, 2011 07:50 PM
Might want to check out VSS , vehicle speed sensor.
Nilsa Apr 10, 2011 06:03 PM
Not only the speedometer, but also the gas indicator and the tachometer
Thanks for your reply, but the problem is with also the tachometer, and gas indicator.
All of the clocks are down; it started with the needles moving
pls advise
tku
Nilsa
inch Apr 22, 2011 04:34 PM
Have same problem
have same trouble anyone had any luck finding cause?Thinking of replaceing cpu
hanky Apr 22, 2011 06:22 PM
The reason I suggested checking the VSS (vehicle speed sensor) is because some manufacturers tied the VSS into the same circuit as some of the rest of the gauges. Unless you were aware of this possibility you would never expect them to share the same circuitry.
Maddog999 Jan 14, 2014 08:17 AM
I have a 2003 that does the same thing. I noticed the dash lights also blink when this happens too. The gauges peg and then go to normal. Did anyone try the VSS ? Or resolve? I was thinking the panel may be bad and replace it. Its just dash screws and a few connections.
