P1744 Trouble Code
Old 02-10-2009, 06:14 PM
mikson's Avatar
Default P1744 Trouble Code
I keep getting 1744 code whenever im driving over 40mph for a period of time usualy 10-15 mins the o/d lights comes on and keeps blinking untill i restart my car. After i restart it it seems to work fine but when the o/d light is blinking car seems to jump everytime there is a gear change it isnt smooth.
Can it be an electrical or mechanical problem?
What would be the best sollution to the problem?
Old 02-12-2009, 09:41 PM
transguy37's Avatar
Hello,
P1744 is excessive TCC slip. Basically, the computer is not seeing enough rpm drop when the torque convertor locks up. It could be mechanical or electrical. When I get to the shop in the mourning, I will find out and let you know.
Old 02-26-2009, 08:31 PM
llf12130's Avatar
Default http://www.liangdianup.com/subpages/airfitting_1.htm
Now that is a lot of brass air fittings there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
roadrunner64
04-20-2013 10:51 AM
Ed Roberts
11-21-2009 08:47 PM
Bronco76Ranger00
11-08-2009 08:24 PM
98 vic
08-20-2005 02:32 AM
bluecam
06-19-2005 09:42 PM
Quick Reply: P1744 Trouble Code
