hanky |
02-15-2015 05:29 PM |
I'm gonna get a lot of flack on this, but In a situation like this you will need to remove the radio section to see the tubing from the heater to the vents, etc., and to disassemble all that stuff to retrieve a jammed pen. Sometimes you can cut a door in the ductwork where you might see the jammed object and possibly retrieve it using a flashlight and mirror. When done, that door can be replaced with some JB weld and the ductwork can still do what it is supposed to do with out any leakage. Otherwise all you can hope for is for the pen to fall away from the door that it may be jammed against and it will just sit in there for the rest of the vehicle's life. Last, but not least ,you can disassemble everything and eventually get the pen out.
