2011 Check engine light tank door not closed
Had tank filler neck replaced because it had a crack at the top of it in the tube. It gave a Check Engine Light. $815.00, 1 week later Check light back on, notice back on display. Is this a common problem?:confused:
Not normally.
For $800+ Suggest that you have place that did the work recheck it. |
