2011 escape --rear park aid
i have a 2011 ford escape 3.0L limited and when i switch to reverse it shows me on dash "Rear Park Aid ON OFF" and the rear park aid doesn t work. I ve tried to use reset button to chosse on or off but i cannot select. I would appreciate some help
hi, i have the same issue and am now looking into it. other options on the computer display have the ability to select on off, as indicated by the <XXX> greater or less than around the selection. but the park aid piece doesn't have the greater or less than options. Have you figured it out? I tried to clean and then replace the four rear park aid sensors but this didn't work. i heard there was a park aid module that might go bad, but not sure where this is right now.
https://cimg5.ibsrv.net/gimg/www.for...97601dc103.jpg |
