2011 Escape starting problem
This has happened 3 times in the last 4 days.
when I turn the key to start it , it turns over great but does not start. when you let go of the key it keeps turning over. if I turn the key off and then try to start it again , once it repeated the above and the other 2 times it started normally. Thanks for any advice on this issue. |
I am having the same problem with my escape. It has been at the dealer for a week now and they have no idea what is wrong with it. Did you find out what was wrong with yours?
It ended up being just bad watery gas.
a couple bottles of dry gas fixed it right up. |
If the suggested fuel answer doesn't work,
either something is keeping the starter engaged electrically or the starter drive for some reason won't return to normal. I believe a different dealership or electrical shop that really looks into it should be able to determine the cause. |
