Ask Me about a Ford.
Old 08-03-2017, 08:59 PM
fogosfishin's Avatar
Default Ask Me about a Ford.
40 yrs. + working on 'em.
Old 08-04-2017, 04:29 AM
trevork's Avatar
What is the voltage of fuel gauge wire of Ford ranger 2.2 T6 when tank is empty as well as when tank is full
Old 08-04-2017, 11:15 AM
Default Fuel gauge readings
There should be 12 volts to the sender. It's not a matter of volts to the gauge. You want a resistance reading. Take ohm meter and move float arm. Should be a steady difference in reading...up or down. Key off.
Old 08-05-2017, 08:07 PM
vaskeet's Avatar
I have a wrecked 2006 i4 4x4 what years would be compatable to use that engine and transmission with on issues
Old 08-17-2017, 05:45 AM
RonWms's Avatar
2013 Ford Escape S. Rodents chewed on several wires in the engine compartment. My mass air sensor connector was completely detached from sensor. I misplaced the original connector now I don't know the proper color sequence for the new connector. The original colors for the 4 wires are yellow, blue, green and purple.
Help Please.
Old 08-17-2017, 04:43 PM
dmkberger's Avatar
Default What oil pan is front sump for 4.6L DOHC?
I am desperately seeking information for a front sump oil pan to fit my 4.6 out of a '95 Lincoln Mark VIII
I'm putting this engine into my '57 Ranchero and it will NOT fit till I find a front sump pan for this engine... What are your thoughts?
I know it can be done, The forum at 57 Fords Forever has two that are already in and rolling down the road. I can't get on the forum for some reason.
I have not been able to get anyone's attention there and have tried contacting them directly, to no avail... HELP!
Old 08-17-2017, 06:25 PM
dmkberger's Avatar
Default Found it!!!!!!
I answered my own question... Lincoln Continental used the 4.6l with the front wheel drive and a Front Sump Oil Pan!!!
Now all I gotta do is find one and make this motor swap happen!!!!!!!!
Old 11-01-2017, 11:06 PM
venture1169's Avatar
Default Need to Know
Can I swap out a 2.5 to a 2.0 in 2011 Escape XLT & If possible where can I get more info on how to do it.
myforddreams
12-17-2019 12:47 PM
petec
08-06-2015 11:37 PM
MorePowerTuning
04-19-2015 10:12 AM
BRETM
03-12-2008 06:30 PM
Quick Reply: Ask Me about a Ford.
