-   Ford Escape (https://www.fordforum.com/forum/ford-escape-19/)
-   -   front end thumping when i hit bumps..help (https://www.fordforum.com/forum/ford-escape-19/front-end-thumping-when-i-hit-bumps-help-6983/)
chachi Feb 7, 2007 03:57 PM
I have a 03 escape limited...when i hit bumps the front end makes a thumping sound....my friend who is a mechanic looked it over and thinks it is the subframe mounts....he lifted the car and said the rear of the subframe dropped...i called the dealership and they said there is no mount and that the subframe is hard bolted to the unitbody....has anyone had this problem?? any diagram?? repair advise? All input appreciated.................Chachi
freez401 Feb 25, 2007 11:15 AM
RE: front end thumping when i hit bumps..help
Same problem here, my wife has a 2002 escape and when she goes over a bump there isa thump in the front end...??
nicroley Aug 26, 2007 12:34 PM
it's the bushings...have them repacked that should help. I hadthe same issue when I got my 2002 used and it was the bushings and after they are fixed try to take it easy on the speed bumps!
surfscape Aug 27, 2007 08:23 AM
Usually the first thing to go is the stabalizer bar links and or mount busings. Then the ball joints. If you lift the car and push on the various components you will see looseness (paly) on the worn parts.
lv2escape Aug 30, 2007 09:38 PM
Don't know if it's the same, but I have a 2002 Escape with 125k miles and it has had a loud popping noise in the front suspension for almost a year and no one could properly diagnose it. Turned out to be a bad/worn outstabilizer bar. My mechanic replaced it for a whopping $40.00 parts and labor. So it was well worththe small price to pay,and the sound is finally gone.
daskivt1679@aol.com May 3, 2008 07:30 PM
had same on one side,,,stabilizer bar links,they run from lower to upper susp.parts tying them together, 25$ a piece,100$ job.replace both at same time
hefty Sep 15, 2008 08:47 PM
We had the same problem. The dealer replaced the stabilizer bars which did not fix the clunk. My husband put in a new stabilizer bar and this took care of the problem.
hefty Sep 15, 2008 08:48 PM
i meant my husband replaced the tie rod.
