-   Ford Escape (https://www.fordforum.com/forum/ford-escape-19/)
-   -   fuse location for Power Point (https://www.fordforum.com/forum/ford-escape-19/fuse-location-power-point-5009/)
jeffreyedgar Aug 28, 2006 08:25 PM
The Power Point is the second cigarette lighter located on the dashboard below the climate control. I plugged in an DC/AC inverter with the result that there is no power. I assume the fuse blew. It is not the same fuse as the cigarette lighter since the cigarette lighter still supplies power. Anyone have knowledge of the fuse location in the fuse panel. I knwo where the panel is. I do not know which fuse in the panel.
Mulletman Aug 29, 2006 02:18 PM
RE: fuse location for Power Point
The Owner's Manual will tell you which fuse it is. If do not have one, I suggest you get one.
gixxer32404 Jan 6, 2008 12:50 AM
I have searched for several days online. I have found what many like myself have been searching for, whickis the early model 91-94 explorer/ rangers fuse diagram, by the emergency brake.here it is:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
(look under diagram for your applicable yr and model,then clickon diagram to enlarge)
the 96 and newer are on that ford site.
https://www.fleet.ford.com/maintenan...ls/default.asp
eddieray Jun 10, 2013 04:08 PM
fordfocus powerpoint fuse location is not listed in owners manual that I see does any one have a idea it is a 2011 ????????????????
Eddie
spillerbd Feb 20, 2015 02:36 PM
For a 2005 Escape,
Position 24 Cigar Lighter 20A **
Power Point is fused in the Power distribution in the engine bay
Position 12, Power Pointe 20A *
haybailer57 Apr 9, 2018 01:09 PM
1998 ranger hi beam fuse is 33 ,7.5 don't buy a new t/s dimmer w/s wiper switch first like me:)
haybailer57 Apr 9, 2018 01:32 PM
not 33 but 34
no fuse in 33 slot nbr 34 was the hi beam. just cked the 24 fuse and is ok with test light
09XSCAPE Apr 9, 2018 03:08 PM
Jeffery
if you noted what year car you have...maybe someone could look in their owner manual for fuse location
...with that said if you know where fuses are...typically a "blown" fuse has visual burn signs on top of fuse
also look at your ac/dc inverter to see what load it draws...it may exceed the circuit for the +12v power point
Hayapower Apr 9, 2018 08:18 PM
The original post is near 12 years old,, and the thread now contains other models..
Certainly the help is appreciated, and try to keep the thread specific to model, otherwise the help request or offerings may be missed by others...
