On-going issues with 2007 Ford Escape
Old Feb 3, 2010 | 03:44 PM
bailey8006's Avatar
Default On-going issues with 2007 Ford Escape
We just had the transmission on our Ford Escape replaced. When we picked it up, we noticed at highway speeds the whole vehicle vibrated. We took the Escape back to the shop that put the new transmission in, and apparently the Drive Shaft is bent. Is there a possibility that this occured during the replacement of the transmission?
Old Feb 3, 2010 | 10:01 PM
digital_diversion's Avatar
There is the possibility...but I would think bad U-joints for that type of vibration...you are speaking about the driveline going from output shaft to the rear end...right?
Have you been four wheelin in it recently?
Old Feb 6, 2010 | 07:01 AM
ralphie250's Avatar
4 wheel drive????
Old Feb 6, 2010 | 09:19 AM
I asked if it has been off road recently...because that might be where the drive line got bent...from high-siding it on a rock or something...
drive lines don't usually get bent from normal use.....
Old Feb 8, 2010 | 06:47 AM
bailey8006's Avatar
It ended up that the dealership had not properly reinstalled the drive shaft after installing the new transmission. They were claiming that they had nothing to do with it, second opinion said otherwise. They have since fixed it at no cost.
Old Feb 8, 2010 | 08:47 PM
johno2355's Avatar
I belive that. those driveshafts are sometimes tricky to get apart and reseated because of the cupped style flange on the shaft.
Old Feb 10, 2010 | 09:48 AM
ralphie250's Avatar
correct!!!!!!
pas1lus
May 5, 2014 07:52 PM
tsawyer123
Apr 29, 2014 02:09 PM
trick427
Jun 27, 2013 12:26 AM
AshleyChereBeaver
Sep 13, 2010 08:00 PM
