vaccum hose diagram 2001 escape
I need vaccum hose routing for 2001 v6 escape. I need part # for hose that goes from rear valve cover to bottom of intake plenem(manifold) after throtle position plate
To get the right part the first time, usually to get it from Ford.
have gone to Ford and looked at thier diagram. Does NOT match what is in my vehicle. I may have connected hoses incorrectly. Not 100% sure. I will try to find another 2001 v6 escape to look at and see. Thanks
There is usually a vacuum diagram on the underhood panel. Is yours still there or has it been removed?
I don't know how many engine variations were available for that year, but if you google "2001 ford escape vacuum diagrams" the one you seek should appear there.
have looked at diagram under hood and internet. i looked under hood of a 2001 v6 escape and took pics with my phone to compare with mine. apparently i hade two vac lines routed incorrectly. I rerouted correctly and seems to run fine. Will know for sure when i start on cold morning. Thanks 4 your help:)
