-   Ford Escape (https://www.fordforum.com/forum/ford-escape-19/)
-   -   Vibration while accelerating between 30-40 mph (https://www.fordforum.com/forum/ford-escape-19/vibration-while-accelerating-between-30-40-mph-24324/)
Dan Tinklenberg May 11, 2011 02:19 PM
Looking for any suggestion on a problem with my 05 Ford Escape Hybrid. Vehicle runs fine but if I am maintaining a speed between 30-40 mph or accelerating between that range I get a really bad vibration. I also get a strange vibration when accelerating through corners. The vibration goes away if I let off the gas, but returns if I accelerate again and still going within that speed range. Thats the reason its so confusing is because a bad tire, or weights being off would continue to vibrate even if I let off the gas. Any suggestions would be greatly appreciated, thanks.
way2old May 11, 2011 07:11 PM
Have you tuned it up? It is possible the engine misfire is only noticeable under a certain speed/load range. A scanner that can read Mode$06 data can pinpoint if a cylinder has misfired.
